I have a MK2 Mixer and I just purchased some tables. Do I have to use a specific type/brand of time coded vinyl? I.e. I know VDJ has there own brand. There is also the Numark one and also Rane Colored Vinyl and the M-Audio. Does anyone know if theres a big difference?
Best Regards,
Matt M
Best Regards,
Matt M
geposted Sat 26 Jan 08 @ 11:42 am
Eventually, you can use all with VDJ, when the plugin and open engine is ready (beta testing still)
As of now, both VDJ and Numark ones work great (are pretty much identical)
geposted Sat 26 Jan 08 @ 11:49 am
Alright sweet thanks alot! I'm going to go pick up my tables today and I wanted to stop by the local store and I know they probably wont carry the VDJ vinyl, but thanks again!
geposted Sat 26 Jan 08 @ 11:52 am
Be advised you do need the Pro version of VDJ for proper Timecode support :)
geposted Sat 26 Jan 08 @ 12:12 pm
Oh its not a support question. Just a general one. But thanks for looking out. Gotta start somewhere.
geposted Sat 26 Jan 08 @ 12:16 pm
Ok let me rephrase that: You need the Pro version for the timecode to work longer than 5 minutes :)
geposted Sat 26 Jan 08 @ 12:23 pm
