I see that there are some software apps that allow the clubbers to text on the screen to flirt or request music.
Does anyone know if this can work in conjunction with VDJ?
Iwall is a software that claims to work with most VDJ software, can I ask a pro in the forums to download it and see if it does work?
Here is the download link.
http://www.download.com/iWall/3000-10440_4-10795724.html?tag=lst-1
Tell me if this works, I would be so excited to implement this.
geposted Sun 27 Jan 08 @ 4:07 am
Unfortunately you cannot inter-grate it with Virtual DJS video Screen , but if you look in the plugins section a kind user is currently developing such a plugin for Virtual DJ.
geposted Sun 27 Jan 08 @ 4:19 am
Hi Sky,
Where abouts in the plug-in section. I wanted to have a look but i can't find it.
Gary
geposted Sun 27 Jan 08 @ 4:19 pm
geposted Sun 27 Jan 08 @ 4:21 pm
Cheers, just found it.
Its a great idea. I've been looking into stand alone packages for some time now and also using CCTV splitters to create a small window in the corner for the text software to run.
Its like a picture in picture effect, similar to the effect you can use on an Edirol V4. You don't even have to run it on the same PC/laptop as VDJ, just a cheap one will do the trick, and of course then you can have it connected to the internet and charge for the texts if you want, collect data and send back promotional texts.
Gary
Gary
geposted Sun 27 Jan 08 @ 4:31 pm
More up-to-date thread on the subject here:
https://virtualdj.com/forums/92604/Virtual_DJ_Plugins/SBDJ_ScrollText.html
I have also managed to integrate iWall with VDJ as well.
geposted Tue 27 Jan 09 @ 2:33 pm
