Just upgraded this weekend from 5.04 to 5.06 and my clipbank doesn't always activate when I play a song that has no video, when it does it doesn't loop even though it is set to do so AND most frustrating is most of the time the next music video I play on that deck come in UPSIDE DOWN. All my music vid's are avi ripped at 720x480 same size and quality as original dvd with either the divx 6 codec or the ligos indeo 5.11 codec. How do I keep them from playing upside down? I had this problem with version 4.3 but don't remember what fixed it in the earlier 5 versions.
geposted Mon 28 Jan 08 @ 8:06 pm
It looks like a codec problem
geposted Tue 29 Jan 08 @ 7:04 am
There is no consistancy between codecs (in other words it does it on videos encoded using either codec). I would hate to think that BOTH codecs would have a problem, especially since they are both super popular codecs.
Anybody else have this problem and if so how did you fix it?
geposted Tue 29 Jan 08 @ 11:40 pm
