Hi !
I wonder if u could use these 4 items with vdj at the same time ?
And if u still could record ur sessions as i could with my djc.
Or does the mixer works seperatly and the xp10´s and the uc33e works as inputs.
( i do not know which words i should use coz im new in dj hardwares )
geposted Mon 29 Nov 04 @ 9:45 am
does nobody knows if this is possible
geposted Thu 02 Dec 04 @ 12:21 pm
You can use 2x xp10 as controllers, one for each deck in virtual dj
The uc33 can be used to control the sample engine, each slider to one sample slot
You then connect the soundcard part of your xp10's to your external mixer.
It works like a charm, and is a setup many pro virtual dj users use at their local clubs ;)
hope that helps ;)
hope that helps ;)
geposted Thu 02 Dec 04 @ 1:54 pm
thx dj in norway.
now there is just one problem left...
the xp10´s is out of stock...
i know u could send em a mail but i think there´s a lot of dj´s that whants it...
so they will be out of stock before there are in stock :(
geposted Thu 02 Dec 04 @ 3:20 pm
don't worry ;) when they are back in stock, there will be more than enough for everybody ;)
by the way, you need to buy the full program for all this to work, but you probably know
geposted Thu 02 Dec 04 @ 3:29 pm
Yup i forgot to mention that.
But i will buy it...
geposted Thu 02 Dec 04 @ 7:30 pm
just to be shure...
is thera anotherone that know if its possible to use a external mixer (like dxm06 or smac pro 20) 2 xp-10´s and a uc33e + vdj
does this set work properly???
I whant some sure answers so i know it is possible...
Thx in advance
Thx in advance
geposted Sat 11 Dec 04 @ 1:33 pm
you asked:
"And if u still could record ur sessions as i could with my djc. Or does the mixer works seperatly and the xp10´s and the uc33e works as inputs"
the answer is no, you won't be able to record your sessions as you could with the djc (through vdj's recording feature). The mixer does work separately and your xp10s plug into the input of your mixer.
VDJ has no clue what you're doing with your mixer's volumes, crossfader, and EQ (whereas with the dj console, those functions are handled by vdj).
so to record your sessions, you'll have to hook the output of your mixer to the sound-in of your computer's soundcard and use a line-in recording software (many good free ones, look on www.tucows.com)
geposted Sat 11 Dec 04 @ 2:14 pm
ok but exept that it work ??? thx
geposted Sat 11 Dec 04 @ 2:21 pm
including the uc33e ???
geposted Sat 11 Dec 04 @ 2:22 pm
well yes, they're all VDJ-certified hardware that you can get from Atomix and that have native mappings for VDJ, so it'll work.
One more thing: the UC33 is just a controler for VDJ's sample section, it doesn't have a sound output.
You'll need to assign the sample output to, let's say, your computer on-board soundcard output, and feed that in a third input of your mixer.
geposted Sun 12 Dec 04 @ 2:22 am
ok thanks 4 all the answers i just wanted ro be 100 % shure that it works .
dj bambi u wrote that the uc33e didn´t have a output and that u have to put in a sound card and the to a third output...
well then the dxm06 is history coz it only got 2 in n 2 out gues i´ll have to buy a smac 20 ...
geposted Mon 13 Dec 04 @ 6:35 am
