Keep in mind this is a mapper issue not a VDJ issue. We want to make that crystal clear.
geposted Mon 04 Feb 08 @ 11:39 am
When I select (karaoke) under Video Effects get a error window that says
“This application has failed to start because d3dx9_33.dll was not found.
Re-installing application may fix this problem.”
I tried re-installing VDJ but still same message.
geposted Mon 04 Feb 08 @ 12:29 pm
Exactly Cyder,
Most issues are linked with external plugins and skins not being updated with the software.
Anyone sensible would not only realise this, but test any new version of VDJ in the same conditions as those in which they perform in.
It can't be said enough, because too many come back crying when their ice cream melts.
geposted Mon 04 Feb 08 @ 12:31 pm
Yes, please be patient. The guys that make these mappers for us, know about it, and are addressing it. The last thing we need is a lot of crying or badgering.
geposted Mon 04 Feb 08 @ 12:36 pm
They meant the d3dx9_33.dll app. Even though the direct X 9, has the same name, you should download and install the new one.
geposted Mon 04 Feb 08 @ 12:39 pm
[/quote]
Will do.
[/quote]
Will do.
geposted Mon 04 Feb 08 @ 12:40 pm
Did you guys manage to upgrade the timecode system? It's still a bit sketch, and even with my SL-1 card, it gave me issues last weekend--really sucked. Timecodes crapped out on me an hour into the set, and I had to switch to Serato.
When will VDJ become a better Digital Vinyl Solution then Serato?
geposted Mon 04 Feb 08 @ 1:02 pm
Didn't see anything about the photo slide show plugin being addressed...hmmmm....
geposted Mon 04 Feb 08 @ 1:09 pm
Will do.
Will do.
It’s a start.
The flashing has to go.
What about scrolling?
geposted Mon 04 Feb 08 @ 1:12 pm
Sorry but this is the most HORRIBLE update that I never made !
I have an horrible noise all the time over my songs and best of all sometimes a BSOD ! This is the first time that I have such a big problem with an update.
I've downgrade on the preview version and all is back running sweet...
Really need help for this or an explanation. MAybe a moderator can put my message in a new thread if it's not appropriate here.
geposted Mon 04 Feb 08 @ 1:32 pm
It’s a start.
Will do.
Will do.
It’s a start.
What??? Please explain.
geposted Mon 04 Feb 08 @ 1:57 pm
Already answered and solved in the French forum
geposted Mon 04 Feb 08 @ 2:39 pm
I've found a problem with 5.0.7 when using it with the HC4500.
On any pitch range other than 100%, if you use the pitch and then try to zero it, it's 0.02% out.
geposted Mon 04 Feb 08 @ 3:02 pm
The looping needs improving. I hope this is done in 5.1
OO
OO
geposted Mon 04 Feb 08 @ 5:45 pm
Sorry we are not in your mind. Which looping? ;-)
geposted Mon 04 Feb 08 @ 6:02 pm
geposted Mon 04 Feb 08 @ 6:09 pm
You guys continue to amaze me. Ask and you shall be rewarded. Thank you!
http://www.virtualdj.com/forums/58527/Wishes_and_new_features/Notation_feature_in_the_playlists_and_organization_of_the_program.html?highlight=vantinedj
I may not be very vocal but I cam glad you guy implemented several of my ideas in the past 4 years I have used the program.
geposted Mon 04 Feb 08 @ 8:27 pm
Double O wrote :
Word. Someone moved the thread into another forum so maybe thats why there wasn't that much chatter about it. I personally thought that not enough people responded, which makes me think that most people here don't understand the importance of looping.
geposted Mon 04 Feb 08 @ 9:15 pm
Gains can now be saved with the files.
Loop saved with the file will come
geposted Tue 05 Feb 08 @ 2:02 am
Thanks for your hard work guys!! Too bad my Turntables arent set up, I have a gig tomorrow. Anyone try this update with TCV? Hows it working
geposted Tue 05 Feb 08 @ 2:25 am
