Disponibile il nuovo aggiornamento per PC e MAC di Virtual DJ 5 giunto ora alla versione 5.0.7
La versione per MAC è ora stabile e non più in fase beta.
Tutti gli utenti registrati possono scaricarlo come al solito gratuitamente da qui http://www.virtualdj.com/update.html
New features:
- added +-100% pitchrange in options, action "pitch_range", item "%pitchrange" in skin textzones
- new ASIO engine (default engine is when "ASIO UltraLatency" is checked, new engine is unchecked and is safer)
- new button to log searches, so you can download after the party the requests you couldn't find
- new auto-gain options (auto+remember, remember, auto, disabled)
- can drag a video file on the video preview window to link with audio-only files
- option in video config to disable link on drop
- actions "Video_Link", "Video_Unlink", browser column "LinkedVideo", search option "LinkedVideo", filter items "LinkedVideo", "HasLinkedVideo".
- can now unlink video by drag&droping the original file (in addition to context menu option still present)
- added "%linkedvideo" in skin textzones
- skin slider "round" are automatically rotated if doesn't have . in this case, optional param "minangle", "maxangle" can specify the rotation angles at 0 and 4096 in degree.
- new skin object , new actions "multibutton", "multibutton_select"
- clipbank plugin can be cloned (clipbank2.dll, etc)
- new karaoke plugin
- compatible with new Hercules DJConsoles (mobile, Rmx)
Fix:
- fixed itunes songs with "&" character
- fixed accents in itunes folders
- fixed pitch/bpm for HC4500
- fixed some minor bugs
Un manuale aggiornato in inglese è disponibile qui http://radio.virtualdj.com/VirtualDJ_5_Rev7_UserGuide.pdf
Topic generale dell'argomento http://www.virtualdj.com/forums/84950/General_Discussion/_NEWS__VirtualDJ_5_0_7.html
Se avete problemi ad utilizzare il plugin del Karaoke scaricatevi le ultime DirectX End-User Runtimes (November 2007) - Italiano
http://www.microsoft.com/downloads/details.aspx?FamilyID=1A2393C0-1B2F-428E-BD79-02DF977D17B8&displaylang=it
New features:
Fix:
geposted Mon 04 Feb 08 @ 1:31 am
consiglio a tutti di stamparsi il manuale, tutte le volte che lo rileggo ..mi accorgo che mi ero perso qualcosa !!!!!
geposted Mon 04 Feb 08 @ 5:50 am
Aggiornato l' xml della lingua italiana alla rev.7:
http://www.virtualdj.com/addons/download.html?addon_id=3986
scaricare e installare per avere tutte le nuove funzioni tradotte in italiano.
geposted Mon 04 Feb 08 @ 11:50 am
Perchè quando esce un nuovo aggiornamento qualcuno di voi di alto livello non da una descrizione dettagliata delle nuove funzionalità introdotte??
Ad esempio vedo che si parla di un karaoke plugin.
Come si avvia e come si utilizza?
geposted Tue 05 Feb 08 @ 5:09 pm
@sischo
perchè normalmente il manuale spiega le funzioni del software ed il forum non ha lo scopo nello specifico di sostituirsi al manuale o all' assistenza tecnica.
Ma in maniera mirata, e grazie all' aiuto di tanti volontari volenterosi, quella di analizzare o approfondire i singoli problemi come il tuo.
Il manuale ora è in inglese e aggiornato ma una ripassata anche all' inglese di certo non fa male:)
Tornando a noi, cosa non ti è chiaro sul plugin karaoke?
geposted Tue 05 Feb 08 @ 5:38 pm
Moramax mi dispiace ma non la penso come te.
Se parliamo di un programma "professionale" e non di un "giocattolino per bimbi", ogni nuova uscita dovrebbe essere corredata di manuale in tutte le lingue. Io me la cavo con l'inglese, ma come la mettiamo con una persona che non conosce nulla di questa lingua??
In una Azienda seria, ogni dipendente ha un ruolo che può essere più o meno fondamentale per il buon funzionamento della stessa quindi se si vogliono fare le cose per bene ci dovrebbe essere:
1) chi crea il manuale in inglese
2) quello che lo traduce in francese
3) quello che lo traduce in spagnolo
4) quello che lo traduce in italiano
Se poi l'idea della Atomix è quella di approfittarsene degli utenti appassionati di questo software per trarne dei profitti a proprio vantaggio, mi sa che non si parla di vera e propria professionalità.
Secondo me la Atomix non dovrebbe fare alcuna distinzione tra un utente inglese e un utente bulgaro!
Tornando a noi, non mi è chiaro nulla di questo plugin:
Come si lancia, come si usa e soprattutto a che cosa serve
geposted Wed 06 Feb 08 @ 12:03 pm
@sischo
non dispiacerti..non sempre si hanno le stesse opinioni, va bene lo stesso!!
Secondo te avere gli aggiornamenti gratuti forse lo reputi un poco affare?
Io mi domando perchè ti lamenti e si fanno i conti nelle tasche ultrui?
Forse hai ragione, l' Atomix che è un' azienda e non vive d' aria dovrebbe a far pagare i vari servizi offerti come gli agiornamenti, l' eservice plugin ecc e allora è giusto che tu pretenda il manuale anche in arabo.
comunque non correrre troppo..chi ha mai detto che il manuale non sarà presente in Italiano....
il manuale è in traduzione....quando avro' finito verrà pubblicato.
Il manuale è in Inglese principalmente perchè è considerata una lingua universale..pian piano arriveranno anche gli altri....
approfittare!!!
mi sembrano parole dure....
la gente che collabora lo fà con spirito e passione..nessuno è obbligato da nessuno.
Inoltre ti posso dimostrare che esistono programmi professionali (ma molto professionali)dove non esiste la traduzione in Italiano..anzi ti dirò di più esistono tanti giochini per bimbi tradotti in italiano!!:)
Comunque si è veramente off forum e off....per cortesia.....grazie
Più tardi ti spiego quello che mi hai chiesto.(che è lo scopo di questo topic)
approfittare!!!
geposted Wed 06 Feb 08 @ 12:12 pm
Resto e comunque rimango dell'opinione che la logica di vendita della Atomix è sbagliata!
Ritorniamo al plugin karaoke
geposted Wed 06 Feb 08 @ 12:39 pm
Il nuovo plugin è stato concepito per gestire una playlist Karaoke in modo più semplice.
Praticamente ti permette di crearti una scaletta delle canzoni che sono state prenotate assegnandogli anche il nome del cantante.
Per cui al conduttore dj o cantante sarà facile capire i brani prenotati o in esecuzione e quindi anche richiamare sul palco gli interessati.
Per attivare il plugin, selezionare su VirtualDD pro 5.0 rev.7 "effects", "video effect" e quindi cliccare su "Karaoke" nella lista dei plugin.
FIG.1
premendo "LIST" (o ACTIVATE se è disattivato) si apre la finestra(FIG.2) dove potete trascinare dal browser i file cdg e quindi creare la playlist. Ad ogni "drag&drop" vi viene chiesto l' inserimento del nome del cantante.
Per riprodurre la playlist premere sul pulsante "freccia sinistra" nella finestra list oppure sul pulsante "NEXT" nella finestra dei plugin.
E possibile chiurere la finestra di fig.2 a piacimente e quindi per riaprirla premere sempre sul pulsante "LIST"(nella chiusure della finestra la playlist non viene persa)
Per ripetere la playlist(cioè i brani non vengono automaticamente cancellati) è sufficiente spuntare "repeat playlist"
Tipica playlist:
FIG.2
Premendo il tasto "ACTIVATE" si abilita sull' uscita video il testo in sovraimpressione (puo' essere configurato a piacimento) i cui valori predefiniti sono:
"titolo del pezzo" by "nome del cantante"----->durante la riproduzione del brano
prepare next:"nome del cantante"----->20 secondi prima della fine del brano(per far preparare il prossimo cantante)
coming next:"titolo sucecsivo" by "cantante"----->tra un brano e l'altro (per annunciare il prossimo cantante).
Per configurare a piacimento testi visualizzati, posizione del testo e tempo di visualizzazzione premere sul tasto "CONFIG" nella pagina dei plugin.
FIG.3
FIG.1
Tipica playlist:
FIG.2
FIG.3
geposted Wed 06 Feb 08 @ 3:05 pm
..tieni sempre presente che gli upgrade sono gratuiti,
e sono anche molto frequenti....
io all'epoca l'ho pagato €99 ... e tutto il resto mi è arrivato dal Cielo
..magari riesco a farti capire meglio il perchè di certe scelte.
comunque non sono d'accordo con la playlist sopra nella JPG
Bazzooka voleva Cantare Holly Dolly - Dolly song
geposted Wed 06 Feb 08 @ 5:32 pm
plugin karaoke plugin karaoke plugin karaoke...
@sicsho: volevo vedere se ad ogni nuovo aggiornamento del software, o all'uscita di una nuova release, la Atomix avesse cambiato nome al programma e ci avesse fatto pagare ogni volta...ragazzi ma avete il senso del denaro? ma io gli bacio le mani alla Atomix!! altro che manuale in italiano...quelli di OTS Tourntables continuano a mandarmi ancora le e-mail (a tre anni e mezzo di distanza) nelle quali mi scrivono quanto sia per me conveniente, visto che ho la licenza PRO, scaricare con "the best price" il nuovo upgrade...
dai che siamo davvero O.F...
bye
bye
geposted Thu 07 Feb 08 @ 3:52 am
il brano più bello in versione karaoke, di sicuro:
bentornato - finalmente - scarabokio
ahah
comunque, alla fine questo plug-in consente di eliminare quei ridicoli registri o pezzi di carta, come vengono denominati più comunemente, su cui gli amanti del genere annotano chi sarà il prossimo a cercare di "ragliare" un brano stupendo del panorama della musica neo-melodica napoletana :D ahahahah grazie alla atomix per questa nuova release ;D
bye
ahah
bye
geposted Thu 07 Feb 08 @ 8:17 am
O.T.
Il messaggio subliminale è stato recepito con molto piacere ;-)
geposted Thu 07 Feb 08 @ 10:26 am
Salve raga dato che non so' una mazza di inglese qualcuno per cortesia mi puo' tradurre questo aggiornamento : - fixed itunes songs with "&" character .
Vuol dire che legge i brani scaricati da Itunes ?
Grazie
Grazie
geposted Wed 13 Feb 08 @ 1:56 pm
Già dalla prima versione della 5.0, se non sbaglio,era compatibile con il files di Itunes.
Indica che i files di Itunes contenente il carattere: & nel titolo, veniva letto sotto forma di errore di lettura o non corretta visualizzazione del titolo e che il problema è stato risolto(fixed).
A me per dirti il carattere inserito nel titolo come accento, non come apostrofo, " ' " , lo leggeva sotto forma di quadratino,lo sostituii con la lettera accentata per risolvere il problema.
Con questa revisione,non servirà mai più sostituire questo tipo di carattere & per poter far funzionare il file o solo visualizzarne correttamente il titolo.
Spero di essere stato esauriente e corretto nelle spiegazioni, per ulteriori delucidazioni, rivolgiti al teamer Moramax.
Mandi
Mandi
geposted Wed 13 Feb 08 @ 2:32 pm
Grazie dj joe, ho' provato mi fa vedere le cover ma non mi analazza i brani, mi da errore. non mi funzia.
geposted Thu 14 Feb 08 @ 5:46 am
@vdpi
VirtualDJ legge i file fi itune non drm cioè gli itune plus...gli altri non vengono letti.
Quote :
Anto22 wrote :
Gestisce i file musicali direttamente da Itunes?
volevo puntualizzare per quanto riguarda itunes:
Virtualdj è compatibile con Itunes non DRM (ITUNES PLUS) e le playlist itunes ma non con i DRM Itunes(FairPlay). (non solo VirtualDJ ma anche in tutti gli altri software della concorrenza).
Quote :
iTunes Store offre anche brani senza protezione DRM di case discografiche partecipanti. Questi brani senza DRM, chiamati iTunes Plus, non hanno alcun tipo di limite di utilizzo e hanno una codifica di qualità migliore.
Quote :
geposted Thu 14 Feb 08 @ 6:28 am
grazie Moramax come sempre molto disponibile, alla fine mi sembrava troppo bello, pero' da una parte non e' giusto pagare dei brani e non poterli usare a parte ItunesPlus.
Vado Ot : esiste un sito dove comprare i brani e usarli liberamente nelle propie serate, a parte i cd rippati.
geposted Thu 14 Feb 08 @ 3:27 pm
Cmq sono DAVVERO CONTRARIATO!!!!
Quando uscirà la versione di Virtual DJ che FINALMENTE farà...
... il caffè? :P
... il caffè? :P
geposted Sun 24 Feb 08 @ 6:46 pm
A meno che non siano brani di pubblico dominio o CC (creative commons) non si può fare, legalmente. Questo finché ci sarà la siae di mezzo. (In America la società ASCAP che sarebbe la Siae Americana è più permissiva tant'è vero che esisti il servizio Napster / Virtual DJ che ti permette con un abbonamento forfettario di suonare live, con una connessione internet attiva, tutti i brani esistenti prelevandoli direttamente dai server napster ma senza, ovviamente, darti la possibilità di suonarli off line, intendo con questo tipo di abbonamento)
geposted Sun 24 Feb 08 @ 6:49 pm
