It's on the net now
http://www.denondj.com/plugin.asp?prod=DN-HC4500&x=23&y=3
-Added Windows Vista support
-Added New Preset, Item #6 > “Jog Trns Int” (Jog Pulse Transfer Interval)
Maybe this will help us to use the controller as it should be - with VDJ
geposted Mon 04 Feb 08 @ 8:39 am
Yes, now works perfect in Native support mode for VDJ
http://denondjforums.com/viewtopic.php?f=31&t=8735&sid=e3052b1d0159b505e46ac410685dcf19
geposted Mon 04 Feb 08 @ 9:29 am
Thank you very much Silvio for your fast fix.
geposted Mon 04 Feb 08 @ 9:43 am
...and thanks to VDJ team for their input and support!
geposted Mon 04 Feb 08 @ 9:55 am
Thanks Mr S
geposted Mon 04 Feb 08 @ 12:11 pm
virtual DJ,,,,,,,,,,, The DAMN BEST MIXER IN THE WORLD>>>>>>>>>>> This is Hugo Boss DJ...... Getting ready for the UMF miami...
geposted Mon 04 Feb 08 @ 8:52 pm
Thanks Silvio, I will report this info into the Italian Forum.
Ciao
Cioce
Ciao
Cioce
geposted Tue 05 Feb 08 @ 2:42 am
Gave it a 4 hour test last night. Looks good so far
Rock Solid. Great sound, especially with wav files.
I'm delighted with the controller and VDJ
geposted Tue 05 Feb 08 @ 3:15 am
Once a Denon fan, always a Denon fan.
Can't say I ever experienced this problem with my 4500/VDJ, but thanks for the fix anyways!
-=Woody=-
-=Woody=-
geposted Tue 05 Feb 08 @ 8:25 am
denon fan
geposted Tue 05 Feb 08 @ 9:27 am
Hi All, I'am looking to upgrade to the DN-HC4500....Is this the best control or is there one better?? Thanks for your help!!!
geposted Wed 06 Feb 08 @ 10:51 am
For a 19" MIDI controller with displays, control of CD players & internal sound card, you bet!
geposted Wed 06 Feb 08 @ 12:57 pm
I just bought the DN-HC4500 last night.
I registerd it, installed it, updated it, and sucessfuly used it at a gig all within about 2 hours.
Call me crazy, but it worked great! I have to say I'm loving the hot starts!!
Now for my questions:
Is their a list of what all the buttons do?
Also are there any recomendations for ASIO settings in the driver and performances tab?
BTW I'm using it in native mode, & I haven't changed anything.
Thx VDJ & Denon for making this work!!!!!
QuadmanDJ
QuadmanDJ
geposted Thu 07 Feb 08 @ 5:08 am
QuadmanDJ
QuadmanDJ
I second that question, whilst pressing buttons seems to indicate their use, there are probably functions and combinations of functions which we don't know about.
A
geposted Thu 07 Feb 08 @ 7:09 am
oky dan
geposted Sat 09 Feb 08 @ 8:12 pm
SWEET!!!! THANK YOU!!! THANK YOU!!! THANK YOU!!!
yes i was shouting thank you to the denon dev team and the VDJ dev team ;-)
i have 1 of these at a club i play at :D YaY!
geposted Sun 10 Feb 08 @ 12:15 am
Jep, some information on what each button's fuction is would be nice
geposted Mon 11 Feb 08 @ 8:01 am
i just hooked up my hc4500 for the first time and I ran the update from denons site however the sound card works great I just can't seem to use the controller at all. How do I get virtual dj to recongnize that the hc4500 is the controller. I activated it from the remote control options but i still have nothing.
On the controller is says PC and if i touch a button it says link but still i can not control the software
Any helop would be great
geposted Fri 22 Feb 08 @ 10:27 am
Did you follow the instructions included with the Denon update - As well as updating the firmware, this involves installing a new ASIO driver and re-installing the USB driver for the HC4500. If you don't do this, it may not work correctly.
Activating it in VDJ is just a mater of activating the HC4500 in the remote control options. Make sure you are using the latest version of VDJ.
geposted Sat 23 Feb 08 @ 1:53 pm
Yes, after you install v1005, follow the included PDF directions on how to uninstall the old driver from your computer.
It should all work out.
geposted Sat 23 Feb 08 @ 4:20 pm
