i dont know if al the hardwares mixers for virtual dj are compatible with atomixmp3 software,or if there is any please letme know thanks.
geposted Mon 04 Feb 08 @ 12:19 pm
Not that many, its a "discontinued" software.
But if you upgrade to VirtualDJ, you have a WIDE range of controllers/mixers etc...
Some seen here:
http://www.virtualdj.com/products/hardware.html
geposted Mon 04 Feb 08 @ 3:10 pm
Norway, there is no mention on the Atomixmp3 site that it was discontinued. They are still selling it for a wopping $89.95... Shouldn't there be a message or notation that the software has been discontinued? If it is discontinued, that means no more updates for it.
geposted Mon 04 Feb 08 @ 3:48 pm
Hi speed.. indeed the atomixmp3 is "discontinued" after v2.3 in 2003, there no more updates to that. Atomixmp3 is the prequel to VDJ timeline..:)
I think it is still sold but to those who will use it at home or just a media player.
geposted Mon 04 Feb 08 @ 3:51 pm
I feel I have to reply in this thread because I feel the automix site should be pulled. I fell into the trap of buying it then stumbling into these forums whilst looking for help only to find out that the software (which is expensive) would not work with a controller.
I did also offer to trade my license (which I'd had for a couple of days) in for the Pro version but all I was offered was the usual discount which I would get by owning the MK2. Automixmp3 appears much higher in a Google search for "mix mp3s" so people end up with a dated product. The site could be used as a window to VDJ.
A simple large banner at the top of the site saying
PLEASE DON'T BUY THIS SOFTWARE AS OUR NEW VDJ IS AVAILABLE HERE!
and then provide a link. Maybe then you won't piss people off at the 1st opportunity
geposted Mon 04 Feb 08 @ 5:21 pm
Agree, it should be more clear that Atomixmp3 is no longer developed.
Its offered as a media player solution for low-end PC's.
But its of course 5 years behind VDJ on development, and not even close to having modern controller support, features etc
geposted Mon 04 Feb 08 @ 5:25 pm
Media Player solution that costs that much. I don't think so. We all have WMP, I Tunes eyc why would anyone "buy" a media player.
This is what it says on the site:
"Hey, Mr DJ ! Looking for a powerful and easy-to-use MP3 DJ mix software ? You found it !
AtomixMP3 is the sharpest MP3 DJ mix software ever, providing one-click BPM beat matching, beat-aware loop engine, live recording, optional dual soundcard output and master tempo functionality"
I think it should just be pulled or sold for £5.00
geposted Thu 07 Feb 08 @ 1:01 pm
Thought I'd just add that in the UK that's called miselling
geposted Mon 11 Feb 08 @ 12:30 pm
Atomix Mp3 is not just a Media Player, I can still mix pretty good on it on low end machine and no one will tell the difference, believe me ;)
It was the program that made me go on Computer mixing :)
geposted Tue 12 Feb 08 @ 12:45 pm
Please! Somebody helpe me. I can´t record the musics. I try record but nothing heppen. When I used the trial version was ok, but after I bougth the AtomixMP3, I can´use. Thanks
geposted Fri 15 Feb 08 @ 1:32 pm
