Hey guys just wondering if anyone as had this problem with the mk2, after pluggin it all in and all the lights turn on the ones that signal if your on effects, cue or loop (its to activate its control if i wasnt clear) turn off and dont turn on again. I have booted my mac from the start with it and the same thing, i have plugged it in everywhere same problem, i have activated and deactivated it from vdj and that has worked once or twice. It works fine on my pc, but i dont use my pc that often.
In conclusion if you are aware or have come across this problem in the past my you please pass on you experience and knowledge of the force to see if we can finally destroy this small problem for GOOD!
thanks marksy
thanks marksy
geposted Mon 04 Feb 08 @ 6:13 pm
