So I DL dvddecrypter and run it, I just for test purposes put in a regular dvd (Actually, it was a girls gone wild dvd, hehe) anyway, so I run the program (dvd-d) and it out puts a file 600mb, and its a .VOB. k, so now what? I installed vegas 5, and try to locate the file while using "All media" and it is showing that the folder is empty. How do I import a dvd rip into vegas?
geposted Wed 06 Feb 08 @ 5:42 pm
K, got it to "see" the file, but now it says I need a PLUG IN to make it read mpg-1 files????? wtf...
geposted Wed 06 Feb 08 @ 5:48 pm
try using vegas 7.0............. i know that vegas 8.0 is out now
you can send me a PM on the plugin issues you have and will see if i can assist you in working it out
working with vegas 5.0 is not good mon
geposted Wed 06 Feb 08 @ 7:52 pm
I agree Vegas 5 does not do VOBs very well. 7 or 8 will do the trick.
geposted Thu 07 Feb 08 @ 9:10 pm
To open VOBS in Vegas, simply rename the filename to MPEG. That usually does the trick ;)
Also be sure you have most codecs installed:
http://ffdshow-tryout.sourceforge.net/
geposted Thu 07 Feb 08 @ 9:29 pm
