first of all, i love the ipod skin, whoever created it thank you.
i do not know how to change the skins, even reading the tutorial, can't get it,
could the person who created it please make the same skin but make the text larger. i really hate having to use my glasses at a gig.
i would really appreciate it
thanks
thanks
geposted Thu 07 Feb 08 @ 4:43 pm
Julio you can modify the font size to your liking unzip the skin and open the xml in text pad
and search for any text which says font , it will say for example font = 20 just increase the value to increase the size , save it and repackage it as a zip.
geposted Thu 07 Feb 08 @ 4:50 pm
thanks for the quick response.....i opened it in wordpad, changed all the font numbers to a higher number, saved it, zipped it, reopened it, went to my program and it didn't change
did i do something else wrong?
geposted Thu 07 Feb 08 @ 5:21 pm
try notepad it will let you save it as an xml which is needed for the skin to work.
geposted Thu 07 Feb 08 @ 5:30 pm
is there a certain area of font i should be increasing the value of
i just want to read the 3 panels of text?
geposted Thu 07 Feb 08 @ 5:34 pm
tried it in notepad....still not increasing the text in my program
oh well
thank you
oh well
thank you
geposted Thu 07 Feb 08 @ 5:50 pm
