I have several AVI files that will play fine in Windows media player, but are very jittery and freeze in VDJ. What might fix this?
geposted Thu 07 Feb 08 @ 8:18 pm
Its impossible to tell from the info you provide, as AVI file is just a container...
"inside" the avi file, there might be all from mpeg, divx, xvid and a whole bunch of other coded films..
To decode films one needs a codec installed, and VDJ supports a WIDE range... but its impossible to support all.
What you can do, is try to use a good codec pack, that will suit almost any file within what codecs are normally used
FFDSHOW one of the best, if not THE best:
http://ffdshow-tryout.sourceforge.net/
geposted Thu 07 Feb 08 @ 9:27 pm
