I have connect In keybord shortcuts two keys with video_trans on deck one and deck two.
And I have A question : Is there any way to change time of this transistion becouse no matter what value I will put in "value Window" The transistion takes the same Time?
geposted Thu 07 Feb 08 @ 8:32 pm
No you can not update the transition behavior through the shortcuts unless you assign a shortcut to the video_trans_param actions. And even then only if the transition uses these parameters to control speed would that work.
geposted Thu 07 Feb 08 @ 9:30 pm
is there any way to controll that behaivior without locking Crossfaders ? maybe is there any way to "reprogram" the transistion to work with CBG like fe. Strobe transistion Does ? It could be very cool ? wouldin't It ?
geposted Thu 07 Feb 08 @ 9:44 pm
