I am spending a LOT of time correcting the BPM, grid, and phase of all my primary dance songs. I wonder:
1) Is there a shortcut that I can create to go directly to the Manual BPM Edit box? Currently, on every song, I have to right click on that song, then select BPM, then select Manual BPM, the select the Edit BPM tab.... all this with a small mouse pad on the laptop. It's very redundant and time consuming.
2) Is there a way to "lock" the BEAT 1 on the grid so that as we are adjusting BPM, the BEAT 1 marker does not drift?
3) Has anybody tried to incorporate a "Test & Correct" feature, like PCDJ RED 5.2? It seems like if the BPM is initially calculated wrong, that there is only a handful of other possibilities that can work. In RED, you can cycle thru the other choices and listen to a loop, and when you get a continuous sounding loop, you know you've got the correct BPM. Very quick and accurate process.
Thank you!
Thank you!
geposted Thu 07 Feb 08 @ 9:17 pm
Think a procedure that would suit you fine is this...
(all are at the same place as you set BPM manually)
1) Go to the first beat of the song - SET ANCHOR
2) Go to 4th beat of the song / or 8th /or 16th... - SET ANCHOR
3) Choose anchor distance (4/8/16 according to above)
Voilva, you have correct BPM and CGBs :)
If BPM is already calculated correct, and you only need to move the anchors (CGBs) to the beats, press my name and read the shortcut setup in my blog
A new BPM engine is in the making, and might be what you say, "guessed possible values" where one can choose
geposted Thu 07 Feb 08 @ 9:21 pm
And there is a shortcut you can set to open the "EDIT BPM" dialogue box
Its called "edit_bpm" in keyboard shortcuts
geposted Thu 07 Feb 08 @ 9:24 pm
btw, to make anchor method work good, use as long anchor distance as possible, prefferably 16 or 32 beats.
and make sure you set the anchor EXACTLY on beat
(having a midi controller with jogs helps )
geposted Thu 07 Feb 08 @ 9:35 pm
PERFECT! That's EXACTLY what I needed. My carpel tunnel thanks you! I incorporated all 5 of those shortcuts, using "B" to open the BPM dialogue box. THANK YOU!
geposted Thu 07 Feb 08 @ 9:52 pm
np ;)
geposted Thu 07 Feb 08 @ 9:54 pm
By the way, I realize that 16 or 32 beats would give more accurate results. One more quick question: When we are lining up Beat 1 marker under the beat, should it be under the center of the beat? Or under the begining of the beat?
geposted Thu 07 Feb 08 @ 9:57 pm
having a situation with this Grid thing.... I understand the measures , 8, 16, 32 etc. but when i set on first beat (the wider marker) and then count to 32 setting the next marker on the first beat as well... my first marker slides off....its not quite true , like its shifting. I have mixed with my ears for years but would like to be able to perform this correctly. if i hit the sync button ... it won't jump off beat (which drives me crazy haha) any help will be appreciated. Michael
geposted Tue 19 Feb 08 @ 4:49 pm
The first beat 8 measures later would actually be on the 33 beat - not 32nd. Maybe that is your problem?
geposted Tue 19 Feb 08 @ 5:03 pm
VDj puts it on center by default. But you can use your own system as long as
all the tracks will follow the same rule :)
geposted Wed 20 Feb 08 @ 1:53 am
Have you heard anything in terms of upcoming upgrade the waveform ( beatgrid ) display, like the one on SSL with different colors ?? I'm just wondering if that has even been considered.
geposted Wed 20 Feb 08 @ 2:26 pm
