Forum: Wishes and new features
Topic: Two Important Needed Features!
1. There should be an automixing option that goes from the very end of one song, to the very beginning of another, disregarding where the louder parts come in.
2. Virtual DJ needs to be more compatible with playlists made in other programs such as winamp and I think tracks shouldn't have to be analized and I shouldn't have to re-create playlists just to play them in Virtual DJ, when they are compatible with my other music programs.
I might be asking for a lot here, but I have been concerned with these ever since I purchased the program and might lose my faith in it if they aren't fixed; (I am starting to use winamp more)
geposted Wed 01 Dec 04 @ 3:59 am
well duffsterlp
both good idea's....
automix whole songs is what i'm waiting for a long time.
they have to fix in 2.07
I create all my playlists using winamp and use them in VDJ.
Sometimes Winamp will leave the drive (c:\, or d:\ and so on) out. I open up the playlist (after I created it in Winamp) in notepad and add the drive by search and replace. After this addition it is working for me
Ewout
duffsterlp:
Concerning idea 1, it exists in the settings (fade=activated + Fade Length=None) but there is a little bug with automix which should be corrected soon ;-) (the automix doesn't load songs of playlist on the decks)
Besides there is my new plugin "Simple_mix" which can be extended to do that in the future
you have to set the effect on by every song it's loaded.
then you can mix yourself. totaly unusefull.
Thank you for your "totaly unusefull" which equals to long time of developping
I don't talk about the current plugin "Simple_Mix" but about an advanced version (automatic) of the plugin that I have created too (not in the downloads) but I need a new action to load songs of the playlist on the decks. So it is better to wait for the bug fix ;-)
