I have used an older version of virtual dj for a few years. In the older version, you can move the pitch up and down in small increments by tapping the +/- button. Now in the newer version, I have not been able to adjust the pitch except by sliding the pitch up and down. The problem is that it is not smooth and adjusts the pitch too much with the slider and I can not figure out how to adjust the pitch..example +1.2 to +1.3 to +1.4 ect. Can anyone help me. Did this feature get deleted with the newer versions.
Thanks!!!
Thanks!!!
geposted Sat 09 Feb 08 @ 9:44 pm
It is still there ... which skin are you using ?
geposted Sat 09 Feb 08 @ 9:57 pm
I'm using the original skin. I have not changed anything...just downloaded a demo years ago version 2.0 and just upgraded last week and the +/- buttons do not physically move the pitch up or down. I have to move the slide manually by clicking on the slide with mouse and moving it. Any suggestions??
geposted Sat 09 Feb 08 @ 10:15 pm
Pretty simple: go to the settings > keyboard shortcuts. Find the [+] and [-] keys
if they have been assigend already, if not put in values of +1 and -1 like this:
[pic]
As you see in this picture, [+] and [-] keys are set with a value of +8 and -8,
while shift+[+] and [-] keys are set to the smallest resolution possible +/-1.
Keyboard shortcuts are a powerful feature, use them to control any frequently
used functions of VDj instantly with keyboard (or midi controller).
Ps.: Now I realised you might be reffering to +/- buttons on the skin. If that's
the case, the code of the skin has to be adjusted. But keyboard/midi controller
are usually much faster than mouse clicking.
[pic]
geposted Sun 10 Feb 08 @ 2:57 am
Yes, I was referring to the plus and minus on the skin...but you were extremely helpful...
Thank You!!! I will try it now.
geposted Tue 12 Feb 08 @ 12:54 am
