Yesterday I made a small mistake: upgrade a day before a gig to 5.0.7 with my herc MK2....
HUGE problems with the sound on stage, so i decided to downgrade to 5.0.6 which worked flawlessly for me.
PROBLEM: no backup of the install.
Is there anyone who can help me (PM or otherwise) to get my registered 5.0.6 back online?
many thanks in forward !
DJ Joop
DJ Joop
geposted Sun 10 Feb 08 @ 8:51 am
I have re-set your account to allow a new full download of the 5.06 install file. You might want to place this file in a back-up folder, or burn it to a CD in case you need it again in the future.
http://www.virtualdj.com/update.html
Please review the changes in this version and the user guide at the link below before you update.
http://www.virtualdj.com/support/index.html
Best Regards,
mp3jrick
Virtual DJ Support Team
Best Regards,
mp3jrick
geposted Sun 10 Feb 08 @ 8:59 am
Best Regards,
mp3jrick
Best Regards,
mp3jrick
Thanks Rick,
you know: every time i look forward to the next update, so ihmo VDJ is as great as its next update haha.... I should have checked first ;-)
Joop
geposted Sun 10 Feb 08 @ 9:10 am
BTW:
Guys, it is always a good idea to save these installs to a folder somewhere so in the event you need it in a hurry you have it.
geposted Sun 10 Feb 08 @ 9:21 am
Joop what was the issues you were experiencing and how did u have your sound setup?? I do know that I had sound issues when using the little mk2 picture in the sound settings set for headphones, here is what works like the old version:
Input: None
Output: Headphone
Soundcard: 4.1
Then select Hercules as the card
Input: None
Output: Headphone
Soundcard: 4.1
geposted Sun 10 Feb 08 @ 3:07 pm
Since this, Chris has brought to my attention that a driver update will fix these console issues with rev 5.07.
Its no different than a Windows update without updating your anti virus, all kinds of weird stuff happens.
It's a good practice for any of us is to keep up on the hardware we run checking for updates frequently, from sound card drivers to directx to hardware drivers. If you don't eventually you will get bitten in the arse.
r
r
geposted Sun 10 Feb 08 @ 3:19 pm
Hey Chris,
I was used to use my MK2 with the following setup
inputs: none
outputs: External mixer
sound card: mk2
firmware: 1.1.13.7
Driver v 3.4.0.0
DJ Api 2.0.8.2
CPL 1.4.3.2
Then i use channel 1&2 for left deck and 3&4 for right deck. This didn't work for me in 5.0.7 !! Withcoming problem is also the button "mastertempo" which was programmed for magic beatmatch in 5.0.6 ... In 5.0.7. this button is rerouted to master tempo... (duh)
All in all i had a very exciting and interesting evening (read: "f#ckin BAD!") and the audience didn't had a clue.. it was business as usual for them...
Now i switched back to 5.0.6 and everything works great...
So what's the deal?!
inputs: none
sound card: mk2
firmware: 1.1.13.7
Driver v 3.4.0.0
DJ Api 2.0.8.2
CPL 1.4.3.2
geposted Sun 10 Feb 08 @ 3:51 pm
Joop3m wrote :
Hey Chris,
inputs: none
sound card: mk2
inputs: none
sound card: mk2
Mine is working just as you described, along with the Master Tempo doing the magic beatmatch and not the master tempo which you say your's is doing now. All in 5.0.7
geposted Sun 10 Feb 08 @ 6:24 pm
Maybe it's the MK2-software.... which drivers/ software do you use?
Joop
geposted Mon 11 Feb 08 @ 2:14 am
Did you press the button in the mk2 software for External Mixer??
geposted Mon 11 Feb 08 @ 2:25 am
Yep.... select settings in VDJ, close, mk2- setting EXTERNAL, open VDJ, check all etc etc etc.... Sometimes the setting has to be set multiple times...... Then sometimes i got problems with the external setting (enable/disable on weird moments at startup)....
But if you all say that this setting is working properly, maybe i need a new installation?
geposted Mon 11 Feb 08 @ 3:07 am
