When mixing tracks i'm getting a small silent space in between tracks when the crossfader goes to the next song-please help.
geposted Sun 10 Feb 08 @ 1:06 pm
Can you give a little more detail of the problem. Are you using a controller. When did it start doing this and what steps are taken to cause this affect. Are you manually crossfading or are you using automix.
geposted Sun 10 Feb 08 @ 1:49 pm
ok as a home additon user to start , there is a setting that adjusts the fade point in songs i think its in the setting area .. adjust it and play with it .. your using the auto fade.. its a pain in the ass.. the new virt dj additons is way better its worth the money.. but for now.. try that .. i will check again later..
insanenightclub
dj
insanenightclub
dj
geposted Sun 10 Feb 08 @ 4:38 pm
Your correct in regard to the setting in config>option>crossfade + crossfade timing slider ...
geposted Mon 11 Feb 08 @ 10:50 am
