Noticed that the link in the main Tips for a mac thread.
Can someone please email me the drivers or point me to them please :) cant find them anywhere :(
cheers in advance
Phil
cheers in advance
Phil
geposted Mon 11 Feb 08 @ 11:05 am
Which drivers do you require?
geposted Mon 11 Feb 08 @ 2:39 pm
The mac ones for the USB soundcards
cheers :)
cheers :)
geposted Mon 11 Feb 08 @ 3:58 pm
There are many hundreds of usb soundcards could you tell me a name or a model of the one you own.
geposted Mon 11 Feb 08 @ 4:00 pm
comodow pd552
cheers
cheers
geposted Mon 11 Feb 08 @ 4:04 pm
Ok this isnt a mac compatable device its a sound card emulator device for windows , it will only work on a pc
you want a DJ/io or similar card.
geposted Mon 11 Feb 08 @ 4:14 pm
it plays back fine from itunes. but in VDJ its like, all distorted. works fine in all other apps :S are you sure theres no way around this?
if it comes to it what card would you reccomend, cheaps poss.
cheers
cheers
geposted Mon 11 Feb 08 @ 4:17 pm
It may be picked up by core audio which will run it at a basic level in osx , you can try to tweak the performance options
Config > performances
set latency to auto , and the slider to fastest
i ausme you want to use headphones if that is the case check out the dj/io from numark.
geposted Mon 11 Feb 08 @ 4:33 pm
can I use a splitter cable or something instead?
cheers
cheers
geposted Tue 12 Feb 08 @ 8:57 am
you can but the quality will be very low , if you intend to do this for buiness purposes i would really get a proper soundcard like the DJ.io designed to work for mac natively.
geposted Tue 12 Feb 08 @ 9:19 am
I want to use the U46DJ USB soundcard with Mac VDJ but get an error when selecting it for Time Code
Error in the sound driver of Core-Audio.
Any help?
using Leopard if that matters
thanks
Jeremy
geposted Wed 13 Feb 08 @ 2:01 pm
Click my name for a mac timecode setup guide.
..........."I want to use the U46DJ USB soundcard with Mac VDJ but get an error when selecting it for Time Code
Any help?
thanks
Jeremy"...........
i have the same problem . . .
Any help?
thanks
Jeremy"...........
geposted Wed 27 Aug 08 @ 8:56 pm
At the moment, in ver 5.2 the only interface that works with timecode is the Virtual Vinyl card and the RMX. Apparently there's a problem with configuring VDJ and the aggregate device on Mac.
geposted Thu 28 Aug 08 @ 3:37 am
