Hi guys, ok… after going thru 3 laptops… I finally got the Dell XPS M1730…
Here are the SPECS:
Dell XPS M1730
Mobile Intel Centrino Core Duo Processor 2.4GHz, 4MB, 800 FSB Merom
2GB, DDR2, 667MHz 2 Dimm for XPS M1730
17 UltraSharp TrueLife Wide screen WUXGA for XPS M1730
NVIDIA SLI Dual GeForce 8700MGT with 512MB GDDR3 Memory
200G 7200RPM SATA Hard Drive Free Fall Sensor
Integrated Sound Blaster Audigy
AGEIA PhysX Physics Accelerator
The thing runs great with all video transitions and all, but there are 2 things that need to be resolved:
1- When video is playing on one Deck and I load a video on the second deck the video that is playing on the screens stops for maybe a second or less.
2- I’m using the Serato interface and when turn on key lock the sound changes, I played around with the settings and cant figure it out, does the quality of the Mp3 or the audio from the videos have to do with it?
I’m running windows Vista Home premium 32 bit… should I switch to XP?
I would really appreciate you help, thanks…
geposted Mon 11 Feb 08 @ 3:00 pm
