can somebody post an the exact way of uploading plug in's and skins in cue 5.0...i keep trying but it just never works...i just need a guide to use pls...
thank ahead of time
thank ahead of time
geposted Tue 12 Feb 08 @ 8:31 am
You just download the .exe installer if its a skin and double click to install it will then apear on the skin tab of Config
Audio fx same process will apear in Effects Audio
Video Fx same again but will apear in Video fx
If you are using an external tool follow the enclosed manual with it for install setings.
geposted Tue 12 Feb 08 @ 9:25 am
i've done that, and the wide screen turntablism worked fine but the vj one i'm realy interested in using doesn't work no matter what i try, it says there's a problem with xlm line 37, and it doesn't load.....
anything will help...thank you
geposted Thu 21 Feb 08 @ 1:04 pm
hey i got denon cd player...i cant seem 2 connect it 2 the virtual dj software can any1 help??
geposted Thu 21 Feb 08 @ 1:38 pm
