ok, this is second time it happened and I am pretty sure it has to do with me using sample feature more often now
I am running 5.06 and it's has been stable since the install
I decided to put my drops back into the sample buttons.
I have about 5 Samples/Drops
Now what happens is VDJ will crash and play every single sample
I have to restart the program to gain controll again
HEllp me~!!??
DJ SMG,
HEllp me~!!??
DJ SMG,
geposted Tue 12 Feb 08 @ 11:22 am
Download and run v5r7 SMG..and please copy/past the crash report here it can be found in C:MyDocumnets/VirtualDJ/Crashguardreport.txt I bet it will help the Dev Team know what is going on with your machine...
geposted Tue 12 Feb 08 @ 11:31 am
Hey Tear kinda scared to upgrade..... amy problems with .07??
geposted Tue 12 Feb 08 @ 12:32 pm
Try it and see,
If you use your herc when gigin' then you MAY experience problems, like I have. If you do download rev7, then I would give it a good test at home first.
If it all goes pear shaped you can always go back to rev6.
Jimmy b
Jimmy b
geposted Tue 12 Feb 08 @ 12:48 pm
I have not experienced any SMG....
geposted Tue 12 Feb 08 @ 1:22 pm
Wait, let me see if I have this right. You are crashing now, but you are afraid to go to rev 7? What's the worst that could happen, you crash again? Read a few more post about the controller you use, and Man Up.
geposted Tue 12 Feb 08 @ 1:30 pm
Ok Fine... I will upgrade after this weekend
to temp fix the problem I have unloaded all samples from the banks..
geposted Thu 14 Feb 08 @ 4:23 pm
