Newegg has a good deal on this laptop and it says it has 256 dedicated graphics card. I want to know do these specs cut it for video mixing with TCV? I have seen alot of post about video cards but it seems people keep suggesting the newest most fastest card but I cant turn around and keep buying the newest thing that comes out. I want to buy VirtualDJ but want to make sure I have a system that can handle it. Will this be suffice?
Model
Brand ASUS
Series F7 Series
Model F7KR-X1
General
Operating System Windows Vista Home Premium
CPU Type AMD Athlon 64 X2 TK-55 1.8G
Screen 17" WXGA+
Memory Size 1GB DDR2
Hard Disk 120GB
Optical Drive DVD Super Multi
Graphics Card ATI Mobility Radeon HD 2400
Video Memory 256MB
Communication Modem, Gigabit LAN and WLAN
Card slot 1 x Express Card
Dimensions 15.8" x 12" x 1.5"
Weight 7.9 lbs.
CPU
CPU Type AMD Mobile Athlon 64 X2
CPU Speed TK-55(1.80GHz)
CPU L2 Cache 2 x 256KB
Display
Screen Size 17.0"
Wide Screen Support Yes
Display Type Wide XGA+
Resolution 1440 x 900
Operating Systems
Graphics
GPU/VPU ATI Mobility Radeon HD 2400
Video Memory Dedicated 256MB
Graphic Type Dedicated Card
Hard Drive
HD Capacity 120GB
HD RPM 5400rpm
HD Interface SATA
Memory
Memory Speed DDR2 667
Memory Size 1GB
Memory Spec 1GB x 1
Model
Brand ASUS
Series F7 Series
Model F7KR-X1
General
Screen 17" WXGA+
Hard Disk 120GB
Video Memory 256MB
Weight 7.9 lbs.
CPU
Display
Screen Size 17.0"
Operating Systems
Graphics
Hard Drive
HD Capacity 120GB
HD RPM 5400rpm
HD Interface SATA
Memory
Memory Size 1GB
Memory Spec 1GB x 1
geposted Tue 12 Feb 08 @ 2:59 pm
considering your comment about always buying the newest thing, i suggest to spec much higher. the spec here will just have you crawling for another machine after 6 months to 1 year which is hardly a good investment. spend more in the range for 2.4ghz processor and your laptop should last your 2 years. go for 7200rpm drives minimum as all pro video needs fast access drives. i'd also recommend looking at a machine that has 2 drives in raid 0 so you will never have seek/read problems. your video card should also be 512mb range as well.
geposted Tue 12 Feb 08 @ 9:31 pm
