I am having a problem. I just set up the midi control with my DJM-800. I assigned the crossfaders together, now I can't hear (in my headphones)the cd player on the right side if the left side is playing on the main. Is there a way I can set this up to be able to hear the opposite cd player?
geposted Thu 14 Feb 08 @ 4:04 pm
Gotta check the manual for the DJM-800
hopefully you are using the mixer for your Cueing/Headphones and not your soundcard.
Thanks,
Thanks,
geposted Thu 14 Feb 08 @ 4:25 pm
Ok, first of all, you should not set up the midi crossfader to control the audio crossfader in VirtualDJ.
(unless you have a spesific reason for it, like Shoutcast broadcast of titles to a radio).
Reason is that the hardware crossfader/mix on the DJM800 is better than a software emulated one, and better for straight-forwards cue/prelisten on the mixer.
Why did you map the crossfader? I would guess it might have to be to control the VIDEO crossfade.
If so, map the midi function to VIDEO crossfade ONLY, and leave the audio crossfade to Pioneer hardware.
That way you can control video crossfade in software (by midi from mixer), and audio in hardware, with cue/prelisten working as it should
Of course, I take it you have a dual output soundcard, with two stereo outs, where each deck in VirtualDJ goes into separate channels at the Pioneer mixer.
Cause you need that :)
geposted Thu 14 Feb 08 @ 4:31 pm
When using external mixers - go to Config -> Options -> Set the Crossfader option to DISABLED
geposted Thu 14 Feb 08 @ 5:44 pm
