Hi !
I was wondering if it is possible to get personal comments for each track visible directly on the "position of the song " field.
This would help me to get an insant picture of when the beat, vocals etc start and fade out in the songs. To be able to get "cuepoint lines" in different colors would also help. Then i would know that red for instans is for the beat and blue for melody etc. To be able to colorize the intire field would help to.
Regards
Regards
geposted Fri 15 Feb 08 @ 1:02 pm
Just add a cue there, and rename it...
geposted Fri 15 Feb 08 @ 1:08 pm
That wont solve my problem. If i add the cue and rename it, the name will only appear if i hold my mouse on it and in the waveform window. I need to see what is going on on an instant so it will go faster for me to find a sutible spot for me to mix it...
geposted Fri 15 Feb 08 @ 1:24 pm
Wow, you want the software to do alot of the work you should already know. Some of the downloadable skins provide a little something more in the wave form. You do have to be a registered member to access these skins and many are leveled for Pro members.
geposted Fri 15 Feb 08 @ 2:14 pm
