TAYLA WROTE:
have you not thought if other guys here are working with the same software with no problems over so many hours there maybe a problem some where else in your set up, just a thought
maybe a conflict going on
I have posted on here many time about the problems i have had with VDJ 5 and on. If traktor scratch works fine and serato works fine with my computer and my korg zero 4 mixer, then i think vdj should work fine! VDJ 4.3 works fine but it doesn't have all the features i use so thats why i keep trying the updates that come out. everytime i do i just get more and more dissapointed with the stablity of this program. i have to go to a gig now so i will list all the problems i've been having and the next time it crashes (which will be soon) i'll have a crash report so someone can tell me whats going on. thanks for your time.
geposted Sat 16 Feb 08 @ 12:05 pm
hope you get it sorted out then
geposted Sat 16 Feb 08 @ 1:22 pm
can't even remember the post, how far back does this go back, still hope you get it sorted
Tayla
Tayla
geposted Sat 16 Feb 08 @ 1:41 pm
