I'm using tccd, can anyboby breakdown the BEATLOCK feature u know pros/cons. I've read the manual but i still would like to have a better understanding of the manual disengage/ on load/ on switch feature.
Thanks in Advance
Thanks in Advance
geposted Mon 18 Feb 08 @ 9:01 am
Please Anyone?
geposted Tue 19 Feb 08 @ 6:45 am
Beatlock is good IF you are using all digital files. If you use an analogue file that has been converted to digital, good luck! You will always encounter CBG drift and need to rely on your super old school DJ Spidey senses to do the mix (gasp) by ear!
geposted Tue 19 Feb 08 @ 12:44 pm
nuff said thanks ronny
geposted Tue 19 Feb 08 @ 2:44 pm
BTW - VDJ is the best of the rest. I have tried them all. Stick with a winner.
geposted Tue 19 Feb 08 @ 3:53 pm
I'm a Torq user and decided to give VDJ a shot and so far i love it. I still use both, Torq has come a long way being on the market for the short period of time (year +), it will get better, but VDJ is my first weapon of choice right now.
geposted Tue 19 Feb 08 @ 6:01 pm
