Hi
I'm trying to make a few tweaks to my favourite skin (Mix Station SV 04) to support my DJ Console a bit better. I use the skin in "full" mode. I've managed to create cue-set protection buttons but I'd also like to be able to put in toggle buttons for the preferences of the jog wheels (either scratch or bend) and the pitch slider (pitch or volume). I've seen that done in the DJC skin, but I can't work out what it is doing in the XML! I can see that it swaps the panels over, and I can see some DJC specific variables at the end of the XML, but so far my efforts to port that across to the Mix Station skin have been something of a failure!
Anyone able to offer some assistance please? What impresses/confuses me is that clicking on the option buttons on the DJC skin actually changes the preferences (you can see this in the remote control preferences section).
Many thanks
r
Many thanks
r
geposted Fri 03 Dec 04 @ 10:13 pm
I think that I can help you with your skin as I know it. E-mail me to share ideas
geposted Sat 04 Dec 04 @ 12:18 am
