I'm surprised there is no section on message boards for this. Its key to my DJ show to present my videos in the right screen..........and not look like an IBM presentation. does anyone use rear projection De Lite plastic screens ?
geposted Tue 19 Feb 08 @ 10:07 pm
dave , the last install that i did was a projector that cost about 180 000.00 . the empire ballroom in edmonton is using led.... Im using a epson sp3 series.. was about 300 on ebay and works in hi- def.. It has more to do with the cables you use to run the projector and what quality of videos your using ... I also have set up 5 different versions of screens .. It is important that you use a screen when projecting from the front to make sure it has silver screen qualities in it.. its a contained fiber glass... makes the screen brighter and less presentation looking.....
geposted Tue 19 Feb 08 @ 10:25 pm
last min thought you can converge two projectors and line them up to increase the color and quality .. use the convergency lines.. i had to do this in calgary at flames central when the imax projector went down....
geposted Thu 21 Feb 08 @ 11:46 am
I use the dalite rear projection screen and I love it. No problems and it takes about 5-10 minutes to set it up by myself.
geposted Thu 21 Feb 08 @ 9:46 pm
tell me more about combining 2 projectors, i think I like that idea........
geposted Fri 22 Feb 08 @ 3:28 am
I'm using the new NEC Wt http://www.necdisplay.com/Products/Series/?series=1a4d6b08-55ee-4d29-94f4-191d7bd88486 its incredible, 100" image from 3 feet away. its also 3 feet below the image so the angles are high for rear projection. I'm testing the da-lite wide angle lense for rear proj screen, will get a sample next week.
tell me more about LED, is the price low enough for high end DJ ?
geposted Sun 24 Feb 08 @ 2:35 pm
Im using a Dell MP2400 (3000 lumens, 2100:1 contrast ratio, less than 1000us dlls) with a short throw lens and a DaLite rear screen. Here is the pic with and without the lens. Notice that theres a lot of light in the room.
http://www.watekedisco.com/Pics/projector_and_lens.jpg
geposted Sun 24 Feb 08 @ 5:23 pm
what is cost of that projector and lens ?
geposted Tue 26 Feb 08 @ 11:45 am
i dont see the short throw lens capability on dells web site - do you have details ?
geposted Tue 26 Feb 08 @ 11:59 am
got it http://accessories.us.dell.com/sna/products/Accessories/productdetail.aspx?c=us&l=en&s=bsd&cs=04&sku=310-8326 but 72" diag image at 8' is good but not quite wide onough for my application, i'm getting 100" at 3' wit hthe NEc but its off axis so not ideal angle for raer projection. the dell is a great price and I may buy it anyway for general use. are there any other short trow products out there ?
geposted Tue 26 Feb 08 @ 12:09 pm
I paid for the:
* projector, same price as published in Dell´s page ($999, 2 years warranty, a nice case)
* Short throw lens, (499 dlls) ouch!!!, but if you are mobile, you must know that every inch of space are very valuable in your instalations.
Both (projector an lens) bought directly from Dell.
* The Screen, its a Da-Lite Fast-Fold 63x84" TEX HighContrast - and I paid 662 dlls for it from B&H Photo & Video store.
I was very pleased with the results, but I just read something that you may be find very interesting for a MSRP of $1192.00,
check that you will not need a lens adapter:
http://www.benq.com/products/Projector/?product=1239
geposted Tue 26 Feb 08 @ 10:43 pm
My Screen:
http://www.djscreen.com/
My Projector:
Sharp Notevision XR-1S
£549.95
Technology: DLP
SVGA
Resolution: 800 x 600
Inputs: Data and Video
Contrast Ratio: 400:1
Brightness: 1200 ANSI Lumens
Weight: 1.4Kgs
Find A Review Here
and here
and another here...
Picture of my old projector:
I still put the Sharp projector in the same place on my mobile rig, but it doens't make it almost topple over with the weight. lol
My Projector:
£549.95
Technology: DLP
SVGA
Weight: 1.4Kgs
Find A Review Here
and here
and another here...
geposted Wed 27 Feb 08 @ 6:53 pm
I use an OPTOMA EP739 2500 Lumens, The thing works great. I also have Da-Lite Front and Rear projection screen. If anyones looking for Da-Lite screens contact me. I am authorized re-seller here in the states and will give deals to Virtual DJ members. The fast fold system is great if your mobile.
geposted Wed 27 Feb 08 @ 9:25 pm
