just a few thought's on video converting from dvd disk ive noticed that over the year there seems to be a shift from mpeg 1 to mpeg 4
being the new kiddy on the block and i was wondering what the best tool for the job. so i did the internet traul for about 2 days
and played with several companies trial versions and found a great little programe which blew me away first from how easy to use
and secondly how fairly cheap it was . i have also noticed that vdj sounds a lot clearer on the new mpeg 4 so if you whant to try it
for your selves guys and girls here is the link .... oh and by the way i use promo only disks
http://www.imtoo.com/
ps if you do go for the programme dvd ripper platinum gives you the mpeg 4 with the best codecs
cheers adeshady
cheers adeshady
geposted Wed 20 Feb 08 @ 10:32 am
weird they expect you to buy both encoders and aslo mpeg4 in different bundles ,.. didn they get the note that the compition has other soft out there that does all of it .. for the price of one.. and also allows you to send videos streaming throught the dongle to copy it at hi def... wow... even pinnacle has this ... rip and zip... boom ,your in bussiness...
geposted Thu 21 Feb 08 @ 11:02 am
