Hey all,
With my Audio8 soundcard, i have some options in the asio driver, to change latency settings, about 5 or 6 presets. From high latency with low CPU usage, to low latency with high CPU usage.
Now i am wondering how to get the best latency settings out of VDJ, with the most stability.
I tried some settings, and at a decent setting, i have about 30% CPU usage, while playing 2 tracks together, with 2 timecode cd's running.
The next step with even lower latency, wil put my CPU usage around 50-60%, and when i push it even further, it'll be at 70-80% CPU usage while playing 2 tracks controlled by timecode.
When i load a track, the CPU does jump to 100% for a sec, but that is even at the highest latency setting, so normal behavior i guess.
Now my question is, will VDJ be playing rock solid stable, when i pick the setting with very low latency, and have 70-80% cpu usage all the time?
Or should i be safe, and take a setting with less CPU usage, but a bit more latency. (which for me, is noticeable, especially when cue'ing)
btw, i run VDJ on a dualcore centrino laptop, with 2Gb ram.
geposted Wed 20 Feb 08 @ 4:29 pm
You are the only one that can answer this question, it's your machine. You will have to run your own test, to see which works better for you. I don't care if my machine runs at high cpu, as long as it continues to play.
geposted Wed 20 Feb 08 @ 4:50 pm
It depends what else is running on the machine, technically, 100% all day should be fine, but this is the real world and it's a bit like your sound system, or car. We need to leave some headroom for "peaks", and of course "overtaking". Or for other processes to catch up!
I always aim to leave 50% free on average, leaving a nice safe margin available. Had no problems so far.
Just remember to do your best to keep it cool.
geposted Wed 20 Feb 08 @ 8:40 pm
