when I select it, it tells me "...d3dx9_32.dll" was not found...." what is this file, where do I get it and where do I install it? I am running 5.06 (tried upgrading to 5.07 and I had random crashing problems I went back to 5.06)
geposted Thu 21 Feb 08 @ 1:33 am
You need to update your DirectX runtime libraries.
Your best bet is to run the DirectX Web Update:
http://www.microsoft.com/downloads/details.aspx?familyid=2da43d38-db71-4c1b-bc6a-9b6652cd92a3&displaylang=en
Regards,
Scott
Regards,
Scott
geposted Thu 21 Feb 08 @ 7:38 am
I solved it by googling that DLL file and put it where it should ;)
geposted Thu 21 Feb 08 @ 10:28 am
