Can you use the VDJ software with mixers like the Pioneer DJMs, Gemini PS series and Numark DXMs?
It's a probably a stupid question but the last time I didn't ask the stupid question I was out of pocket €120.
Thanks .
Thanks .
geposted Thu 21 Feb 08 @ 6:37 am
Yes you can, but you need a soundcard with at least 2 outputs I think.
Output 1 of the soundcard for channel 1 of the mixer and the other output for channel 2.
Jimmy b
Jimmy b
geposted Thu 21 Feb 08 @ 6:50 am
Ah, thank you. I don't know much about soundcards. I've seen them for €30 - €40 but I was recomended one by a store (for a midi controller) and that one cost €150. That's a big difference.
geposted Thu 21 Feb 08 @ 7:06 am
You can use 4 channel sound card with any hardware mixer like with cd players.
geposted Thu 21 Feb 08 @ 8:10 am
melonie
in the meantime if you haven't got a sound card you can try this
basically if you cant follow the clip
go to config
soundsetup
outputs > external mixer
soundcards > mono seperated
output channels give you white lead/left channel red lead/right channel to your mixer
you will have to use a y splitter for each channel to get dual inputs into mixing desk
which of course will only give you mono sound output.
hope that helps
Tayla
geposted Thu 21 Feb 08 @ 12:14 pm
Thank you everyone. So it looks like I will need to purchase extra items. Well, I'm sure it will be worth it in the end!
geposted Fri 22 Feb 08 @ 4:29 am
This may also help:
I use the Rane MP22z ... in my opinion; a solid mixer without many bells and whistles.
One of the mixer's short commings is it's lack of total Kill from the EQ knobs, so I considered purchasing a mixer with total kills (I particularly like killing the bass of the incoming track).
Since I use VDJ's VIDEO skin, I'd forgotten that VDJ has a built-in EQ - and it's a darn good one at totally killing any frequency.
I was able to easily create a couple of keyboard shortcuts to kill Deck 1 and Deck 2's bass respectively and Viola! didn't need to spend more $$$$ on a new mixer with full kills.
VDJ is simply AWESOME !!!!
geposted Fri 22 Feb 08 @ 11:00 am
this will be a good way to go also buy a usb sound card like maya usb 5.1
geposted Sun 24 Feb 08 @ 6:19 am
