.......the answer will, of course, be blindingly obvious and i will go "doh!" when i find out, but the question need to be posed "how do i start the decks at exactly the same time (and lock them together so that if i use backspin or break they go back together)?". your thoughts, please
geposted Thu 21 Feb 08 @ 7:44 am
You can make a shortcut on a keyboard or midi device to do that.
geposted Thu 21 Feb 08 @ 8:08 am
thanx for that DJ-ALF - how do you actually do it, then?
geposted Thu 21 Feb 08 @ 8:12 am
hi again DJ-ALF. i notice from the picture next to your name that you (may?) have the hecules 2 hardware that goes with Vdj. is it a good bit of kit (is the sound card 24/96 etc)?? ta
geposted Thu 21 Feb 08 @ 8:19 am
You can make shortcuts in settings, you will need player section and assign the play/stutter button for both decks.
Yes, I use MK2 with external hardware mixer and it has great sound but I don't use it at 24bit/96khz, just ordinary 16bit 44,1khz as you don't need more than that in a club.
geposted Thu 21 Feb 08 @ 10:28 am
