I'm a pro DJ using VDJ for a few years now and would like to move to a hardware controller. I know there's a bunch of them available, but I wanted to hear from VDJ users which one they're using and would recommend for this software?
Thanks for your help with this.
Howard
Howard
geposted Thu 21 Feb 08 @ 7:54 am
Hi
I use Hercules MK2 and looking forward to get Vestax VCI-100 or new Hercules RMX. You can see more on this subject here:
http://www.virtualdj.com/forums/59874/General_Discussion/the_ultimate_guide_to_controllers___which_ones_right_for_you___and_tech_help__).html
geposted Thu 21 Feb 08 @ 8:07 am
how much you wand to spend?
geposted Thu 21 Feb 08 @ 8:13 am
If i were you i would hold out until the release of the Hercules RMX (Which is just over a month from now i believe)
Wait and see what the feedback is like for this device, then compare prices and review of it to all the other devices which are around at present. Factor in your personal requirements/preferences & budget, then make an a well informed decision from your research.
geposted Thu 21 Feb 08 @ 9:12 am
You can see the video in action here:
http://www.gearwire.com/media/hercules-dj-console-rmx.wmv
Release date is 30 March 2008
geposted Thu 21 Feb 08 @ 10:10 am
Thanks for your help, all. It really gives me a good start as to what to look for.
Howard
Howard
geposted Sun 02 Mar 08 @ 3:13 pm
I think it greatly depends on what you functionality you want/need, and importantly what your budget is... for example I'm using an Ecler Evo 5 and a Denon HC4500 which is in a slightly different price bracket to something like the Herc RMX.
Regards,
Scott
Regards,
Scott
geposted Sun 02 Mar 08 @ 7:57 pm
Do you need rack mount or tabletop, with or without sound card? This will help eliminate a few controllers.
geposted Mon 03 Mar 08 @ 2:20 pm
