ok i made a really big mix with vdj and recorded it and now some of my songs in the begining are starting to sound bad anyone know of any software that can improve the sound quality????
geposted Thu 21 Feb 08 @ 9:57 pm
yeah, you can normalize and clean it up in cool edit , its easy and cheap.. well kinda cheap..
geposted Fri 22 Feb 08 @ 12:13 am
I'm slightly confused by your question.
You say they are starting to sound bad. So they never use to?
Also you say they only sound bad at the beginning. How exactly are you recording?
Ultimately the quality can be made to sound better on the ear, but when dealing with low quality you tend only to be able mask the problem, it's impossible to restore to true orgiinal quality once the quality has been lost.
geposted Fri 22 Feb 08 @ 3:43 am
only thing i think of is increasing the bitrate of your recording on the record config...
geposted Fri 22 Feb 08 @ 6:45 pm
