If I wanted to add the computer grid, Flanger, and Flippin Double effects to the 3 assignable FX buttons on the Herc, how would I do that?
geposted Fri 22 Feb 08 @ 11:20 am
You could download and use DJ Cel mapper ;)
http://www.virtualdj.com/addons/view.html?type=tool
geposted Fri 22 Feb 08 @ 11:23 am
That looks interesting. I'm pretty happy with the default mapping overall, and I just really want to add those effects. Could you tell me... will this mapper reconfigure everything? Is there a way to know exactly what this mapper is changing?
geposted Fri 22 Feb 08 @ 11:40 am
You could configure/assigned it in any way u want..
I did not use the mapper as i only use the mk2 as a soundcard/controller to my external mixer. I prefer the fx stay in the way there are now;)
Someone who using the mapper could give u more review on it..
geposted Fri 22 Feb 08 @ 11:47 am
I dont use the FX button on MK2 but you can cycle through the affects using I think # 1 & 3 buttons and applying using # 2... Only the limited editition is stuck on which affects is assigned. The pro version can be cycled as needed.
geposted Fri 22 Feb 08 @ 12:14 pm
click on (effects) then click on (external devices) then click on (djc) then click on (interface open) click on the button in the interface window on the computer you want to change in this case we will click on button #3 in the interface window on the computer there a small window with the effect for the button you select in my case it read (effect_select_multi) in that window scroll up or down to (effect_activate) select (string) a small window open in there write what ever effect you want in this case i will write (beatgrid) and click on (apply) and thats it
i dont now how to post pic in here other wise i would had sorry
hope i could be some tipe of help
geposted Fri 22 Feb 08 @ 2:21 pm
This is the way I use it. I like that I have all the effects at my fingertips in this way, and you know which one is active by looking at the button next to the platter in some of the skins (I use Mix Lab, for instance).
geposted Fri 22 Feb 08 @ 3:46 pm
Thanks guys. I will try both of these methods out tommorrow.
geposted Sat 23 Feb 08 @ 10:18 pm
