hey guys i had a question..when i press cue on my mk2 it stops and takes me to the start of the song..is their a way i can hot cue??..please any help is appreciated...thanx
geposted Fri 22 Feb 08 @ 8:31 pm
anyone please....help
geposted Mon 25 Feb 08 @ 8:39 pm
heya, why don't u create cue points in the tracks n use the keyboard shortcut instead of pressing cue on mk2.
PS: N pls just use the thread at the technical forum, no need to do double posting on same matter. It will cause confusion n by all means it does not make u get responses quicker. Thanks.
http://www.virtualdj.com/forums/85935/PC_Version_Technical_Support/Mk2_crashing_when_i_use_the_internet.html
geposted Mon 25 Feb 08 @ 8:42 pm
the cue on the mk2 works as fallow it will play the cue if set or set it other wise in another world when you press #1 it will always take you to the first cue in most casses is the beggining of the song or the cue point where you start your mix
cue#2 & cue #3 you can preset or do it on the fly to do it on the fly all you have to do is press the cue button #2 or #3 at the disire point of the song after that they are set
onces they are set you can't change them until you erase them
( in enghlish means you are stock with them until you delete the cue already set wicth you can't delete them on the fly )
geposted Tue 26 Feb 08 @ 11:27 am
