i took a few hours to customize my shortcuts to my liking....
the one particular one that was that was the most needed to change was the shortcut to load a file onto a specific deck... the tab enter was having to many mishaps
the load from sidelist and playlist worked flawlessly, but the load from "filepath" didnt exactly work
anyone know what im doing wrong? im trying to make it shift , and shift . to load the 2 decks
im running the latest by the way
geposted Sat 23 Feb 08 @ 9:16 pm
In shortcuts on left side choose "all". Then on right side of list choose "Load Filepath".
Then in drop down box choose which deck to load. You will need to repeat this for the
other deck. Of course you will need to choose the keys for shortcut.
geposted Sun 24 Feb 08 @ 6:57 am
thats exactly what i did - set it on deck 1, shift (,) and value box not checked. not working
if i do the same for playlist, it does work
geposted Sun 24 Feb 08 @ 9:46 am
Are the shift keys already assigned as a shortcut? Meaing they were assigned before you tried
to make them your shortcut. If so I believe you need to delete the original shortcut and then re assign them.
Maybe try a different key for the shortcut. I had these shortcuts at one point and they did work for me.
Sorry but I don't have any other solutions.
geposted Mon 25 Feb 08 @ 9:44 am
hey man, i tried different buttons, still didnt work
do i check the value box at all?
geposted Tue 26 Feb 08 @ 9:57 pm
