Sup People,
I've record a loop sample from my deck in to my sampler, but my volume is too low when i play it back. I've raised the volume on the deck gain, but nothing. Please Help
Thanks in Advance
Thanks in Advance
geposted Sun 24 Feb 08 @ 8:01 pm
Re-Record it again with a slightly higher gain, ain't really nothing else to do but that
geposted Sun 24 Feb 08 @ 8:30 pm
re record it at full volume and use the sampler volume to decrease the volume.
check your sound settings to see where it's going out. if use of external mixer, raise/lower volume there.
dj shahar
dj shahar
geposted Sun 24 Feb 08 @ 8:55 pm
Thanks guys for your input but i tried to re record @ higher volumes and no luck so far. For some reason even if I higher the volume still gives me the same result. (low volume sample)
geposted Mon 25 Feb 08 @ 4:38 pm
I love VDJ, but the sampler need serious improvement. I dont think there is anything you can do to fix it.
geposted Mon 25 Feb 08 @ 6:21 pm
When you record a sample, is it recorded through the internal mic from the computer. I tried turning that up but it did not work or is it recorded in the line in port. I did not try turning this up since I just thought about it.
I was organizing and recording new samples and just realized the volume differences. I also just realized that you can have seperate folders labled whatever you want ei sampler, Drops...
geposted Fri 11 Apr 08 @ 11:50 am
