hey there guys, this happened again in my practice session today...
the sync button got stuck, ie it wont turn off... i never use it unless i press shift space to auto bpm for quick transitions
what is the shortcut to take this off? last versions it was right click it but it's staying still
geposted Mon 25 Feb 08 @ 6:27 pm
you have short cuts enabled just tick the disable box in "keyboard shortcuts" or you can find that particular shortcut and just delete that one if you use any others
Tayla
Tayla
geposted Mon 25 Feb 08 @ 6:35 pm
or maybe u accidentally pressed b on the keyboard. press b again to disable it.
geposted Mon 25 Feb 08 @ 7:58 pm
b.... oh that might be it
does that perm. turn on the sync?
edit. just tried it, and yup you're right its b... what is it?
geposted Mon 25 Feb 08 @ 8:13 pm
B for beatlock ;)
geposted Mon 25 Feb 08 @ 8:20 pm
wow. im an idiot... thanks man - mad props
geposted Mon 25 Feb 08 @ 8:41 pm
Np, we all learn something new everyday;)
geposted Mon 25 Feb 08 @ 8:57 pm
And if you're like me..... forget it the next!!
geposted Tue 26 Feb 08 @ 10:00 am
