Hi,
i would like to mention that VDJ doesn't recognize already-analysed-songs (in folders browser) if they have been modified with a tool like "mp3gain".
In database, they are still present if you browse it, but if you want to go through your directories tree, they are displayed like new songs (without comments/bpm..).
If you could find some fix for that or some functions like merge database data with folders browser data...
(and no, i have tried to make a quick analysis, it's worse, you even loose all your comments/bpm in database if you do so).
geposted Sun 05 Dec 04 @ 11:10 pm
...I'ts not a bug... it's a feature...
really !
really !
geposted Mon 06 Dec 04 @ 1:23 am
yeah, a questionable feature :)
I say dump the filesize and just use the filename as unique identifier.
That being said, I often use mp3gain (set to 89db) too, before analysing tracks thru VDJ. I like it a lot, it gives great results, and it lets you turn off the auto-gain in VDJ. But since part of VDJ's analysis is gain analysis, you would probably want to re-analyse your track anyway after you've modified its gain throughout (mp3gain adjust the gain bit of each mp3 frame).
Nicolas
Nicolas
geposted Mon 06 Dec 04 @ 8:49 am
It's not that i want but after having analysed and cued my new songs for a whole night, i decided to raise the gain of all my files and it was nice to see at the beginning of the party on the evening that i had nothing left of my hard work the night before..
Thanks djbambi for your interesting hint, gonna do this now cuz i don't want to re-work on all my files.
It would be nice to customise this way a gui option in config panel.
geposted Tue 14 Dec 04 @ 7:58 am
