I get the following message when trying the new karaoke plugin with Vista.
This application has failed to start because d3dx9_33.dll was not fond.
Re-installing the application may fix this problem.
The recomended Direct X runtime does not help. Vista ships with the Direct X 10.
The direct x 9 plugin does not work for me on my computer or laptop with Vista.
From what I understand Direct X 10 is not backward compatable.
Has anyone gotten the karaoke plugin to work with vista?
geposted Thu 28 Feb 08 @ 8:14 pm
There is a Vista Direct x update. Search the web for direct x 10 update.
geposted Thu 28 Feb 08 @ 11:39 pm
I tried the update it does not work, and from what I am finding it does not update direct x 10, and there is no direct x 10 update.
Has anyone goten the Karaoke plugin to work with Vista?
geposted Fri 29 Feb 08 @ 12:31 am
I have Vista and mine works fine, I believe I installed an update as I had the same issue as you.
geposted Fri 29 Feb 08 @ 12:49 am
Thanks for the reply,
Ok I got it to work on my desktop.
I installed the DirectX End-User Runtime Web Installer
http://www.microsoft.com/downloads/details.aspx?FamilyId=2DA43D38-DB71-4C1B-BC6A-9B6652CD92A3&displaylang=en
The instuctions in this forum had a link to the DirectX End-User Runtimes.
http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=1a2393c0-1b2f-428e-bd79-02df977d17b8
This one will not work with Vista.
According to the documentation of the Web Installer it is installing DirectX 9, so I am going backwards.
Hopfully in the future Virtual Dj will support DirectX 10.
geposted Fri 29 Feb 08 @ 10:43 am
I dont think it changes the fact that Vista utilizes DirectX 10, I just think the plugin is looking for a directx 9 file. I could be wrong, but I still think Vista is still using Direct X 10.
geposted Fri 29 Feb 08 @ 1:57 pm
Got the same problem.
Downloaded and installed direcx_nov2007_redist,exe somewhere from the internet.
Problem solved.
Problem solved.
geposted Sat 01 Mar 08 @ 8:20 am
geposted Sat 01 Mar 08 @ 8:27 am
