Hello,
My laptop has a little freez problem when I load a second video while the first is playing.
Laptop has a 512 shared ATI 2600 videocard and memory is 3 gb.
Wich service can I disable without any problem.
I will only use the laptop for gigs, so no internet or something else.
geposted Fri 29 Feb 08 @ 4:47 pm
Is the actual software freezing or is the Main video output freezing or monitor window freezing but not the output?
geposted Fri 29 Feb 08 @ 5:03 pm
I've written a little thing on which vista services I have running in my blog.
<---------------------- Just click on my name to find it.
Let us know how you get on.
geposted Fri 29 Feb 08 @ 6:31 pm
Did all the things you did with the manual services.
Rebooted but still freezing problems.
THIS IS MY FOURTH LAPTOP IN A HALF YEAR WITH VIDEO FREEZ PROBS !!!
MY LAPTOP:
http://www.laptops4u.nl/info/f3ka-ap063c-1671.html
Almost want to give it up
MY LAPTOP:
geposted Sat 01 Mar 08 @ 7:26 am
Now it's just a little freezing with this option in virtualdj :
Preset = Fastest
Latency = 2048
Safe mode and Overclock marked
Basic interpolation
Simple algorithm
Master tempo is fast
Can't get it better without a fraction of freezing
Preset = Fastest
Latency = 2048
Basic interpolation
Simple algorithm
geposted Sat 01 Mar 08 @ 8:40 am
Here are some tips for Vista.
Right Click My Computer > Properties.
Choose Advanced system settings then coose Advanced tab > Performance
Visual Effects tab choose Adjust for best performance
Advanced tab choose Adjust for best performance Programs
Use Vista's Ready Boost option with a 2GB USB 2 memory stick. http://www.microsoft.com/windows/products/windowsvista/features/details/readyboost.mspx
geposted Sat 01 Mar 08 @ 5:02 pm
It didn't help.
Also didn't help the boost external hd.
Gonna install xp.
Gonna install xp.
geposted Sun 02 Mar 08 @ 1:14 pm
i don't know why will you buy a laptop with shared videocard memory,it not good to do
geposted Sun 02 Mar 08 @ 1:24 pm
Because it doesn't matter if it's shared or not.
On this forum, they told me that de Nvidia 8 was the problem and not the shared memory.
Some people here, gave me the advice to buy a laptop with an ATI card.
The problem was the Nvidia card they said.
I believed it because last half year I had these problems with laptops that has a Nvidia 8 ... card.
geposted Sun 02 Mar 08 @ 1:31 pm
