Hi i was wandering if there is a plug in or something that will play my play lists with out trying to mix them?
i know this kinda misses the point of using virtual DJ but i use VDJ at times for singing and i cant have the backing tracks mixing if they would stop then play the next track that would be good
any ideas? instead of using media player
cheers
cheers
geposted Sun 02 Mar 08 @ 9:25 am
Just select the automix type to be back to back, without any overlap. Or disengage automix altogether.
geposted Sun 02 Mar 08 @ 11:46 pm
automix type: fade(remove silence)
automix length: 0s
automix length: 0s
geposted Mon 03 Mar 08 @ 1:01 am
hi thanks for comments but none of them options are on my version:(
geposted Mon 28 Apr 08 @ 7:43 am
