Is the Numark Cue LE thats comes with Total Control, a Proffesional Version, where i would be able to download all the plug ins?
or is it a older version?
geposted Sun 02 Mar 08 @ 2:40 pm
You know the score with consoles as you own the mk2 , you get a limited version free with the console with limited fx and actions , as a gift to get you started your buying the console not the software.
You will need to buy full Cue or VDJ if you would like the full features of pro , to be honest it would be cheaper to buy VDJ as it has the upgrade offer for the herc.
geposted Sun 02 Mar 08 @ 3:16 pm
