Forum: Old versions
Topic: CDJ-400 ASIO driver (PC) - Page: 1
geposted Mon 03 Mar 08 @ 8:32 am
Nice, now we just have to wait for native support to get the fullest out of VDJ :)
Thanx for the links..
Well lets hope that there will be a perfect mapping (like iCdx) soon and all configurations problems will be solved :-)
/Fredrik
Can someone please help me?
I downloaded the driver and installed it.
Than I connected the cdj-400's.
My Remote Controle is:
- general midi
My Sound Setup is:
- inputs: timecodes
- outputs: external mixer
- soundcards: asio drivers
- asio driver: pioneer cdj400 asio
- input channels: chan 1&2 left deck / chan 3&4 right deck
- output channels: left deck chan 1&2 / right deck chan 3&4
Is that owkay? Because VDJ says that there are to many channels..
thank you...
The CDJ-400 are output only .... you can not use them with timecode.
so i've got the cdj 400 and want to use the virtual dj along wit it....
now is there a specific version of virtual dj i need to have to be able to use my player on the vdj???
so far my sound is setup as
-INPUT: none
-OUTPUT: external mixer
-SOUND CARD: 2cards
-SOUND (1): cdj 400
-SOUND (2): cdj 400
the part i dont get is how to set the "REMOTE CONTROL" features...
i need help wit that please!!!
i can control the sound wit the mixer when i play a song off my laptop, but the cdj seem to jus sit there...
hope im makin some sense...
NO NO NO..
Last I checked VDJ has native CDJ400 support.. No need for timecode, just plugin USB and set the CDJ to PC mode and select the CDJ400 as input device in VDJ..
Again last I checked..
If you are experiencing any issues relating to your ASIO SOUND DRIVER when opening your Virtual DJ 6.0, go to his site and download the software to fix the issue: http://www.asio4all.com/
As soon as you download, open up your virtual DJ and everything will operate normally without any ASIO ERRORS!!!!!
hola:
miren acavo de comprar un denon hc 5000 y no puedo hacer que funcione con virtual si me pueden ayudar seria muy util
...muchas gracias y asta luego.
Sorry, this forum is for English language messages only.
Please either re-post your message in English or post it in the correct language forum https://virtualdj.com/forums/
Also, if your message does not have anything to do with Pioneer CDJ-400 ASIO drivers (You mention HC5000, so this is probably the case), then please open your own new topic rather than hijacking an existing thread that is unrelated to your question.
Is this also campstible with Mac OS X?
καλησπερα , ψαχνω να βρω ενα LINK για τους drivers PIONEER CDJ 450 , μπορει καποιος να με βοηθησει ? ευχαριστω
The problem I have is that both cdj-400 appear in channel 1 (display and signal), and I cant´make them be in channels 1&2
plz send me the link to use nxaudio cdj700s asio driver
Your post is not related to the subject of this thread.
If the CDJ700 has an ASIO driver, it will be supplied with the product. If there was no driver supplied then a driver is not required.
If you are sure that the product requires an ASIO driver (if it is mentioned in the product manual) then you need to contact the manufacturer.
91%
