Topic: Will this G-Force plug-in work with VDJ
geposted Mon 03 Mar 08 @ 12:44 pm
Not sure what format are those? Did not use it but If it in .svp, maybe it "could" werk.
But best bet is to use the sonique downloaded from this site as it had been tested safe for usage.
Some sonique out there in the net can be dangerous n can cause crash while u using the software.
Maybe u can try to download the sonique from the download plugin area but maybe it for professional user only as i see it created for VDJ 5.. if so, I'm sorry for leading u there, can't help u much :(
Regards.
I don't think they include a Sonique version any more...
If you buy the Platinum package of G-Force, it will allow you to use it with any audio signal.
So yes, it will work with VDJ. BUT, you won't need to select it inside of VDJ, simply set it to listen to anything coming out of your soundcard, or have it listening to the line-in port if you use an external mixer.
Is this theory, or you have actually used with VDJ?
djdawson,
So does this mean that I need another type player playing that is running G-Force and set to the main screen? How would this work? I don't really wanted anything else running under VDJ. I was hoping that it wouldl be autiomatic when an MP3 is played that G-force will switch on to replace the music video.
But you won't be able to host it inside VDJ, thus won't be able to mix between this and videos and other plugins...
