Someone posted a question about this a while ago and did not get an answer. So in addition to being a mixer, is the mackie d4 also a four channel sound card? Can I run my Time coded vinyl's through 2 channels, with out an external box (Maya, Audio DJ 8, Scratch box) and use the sampler through the third channel on the mixer?
I ask because I am about to drop $400 on the Naitve Instruments Audio DJ 8, well for $400 more I can get a whole mixer.
geposted Wed 05 Mar 08 @ 9:49 am
In addition of this question, i want to buy a Mackie d.4, but i want to know if it works with VDJ??? are they compatible???
Thanks!!
Thanks!!
geposted Wed 07 May 08 @ 12:02 pm
after looking at a photo, and reading the specs, of the D4 no it's not a soundcard. As far as it working with VDJ, it will work fine just like any other mixer would. It does not support Midi so you will not be able to map any of VDJ feature to it. But the fact that's it's a mackie means it will be a quality mixer, with a clean sound, that will last a long time
geposted Wed 07 May 08 @ 1:51 pm
