I'm using Numark Cue LE that came with my Total Control. I've been playing around with videos and it works great!
My question is this:
If you're mixing videos song for song....what do you do when you run out of videos? Is there a way I can thrown in some random still image in there is there a way for the software to grab various images out of a folder for me?
geposted Wed 05 Mar 08 @ 11:35 pm
Why yes there is. There are visuals that go to the beat, that you can tell the software to use, when you are only playing audio. There are unlimited amounts of visual clips available, or you can use your own, including movie clips. Most of these can only be used with the pro version, but you can try. Did I mention that most if not all of them are free?
geposted Wed 05 Mar 08 @ 11:46 pm
Thanks a bunch for your reply. How do I set something like that up?
For example, I want to mix audio tracks on decks 1 and 2 and I'm wondering how I can load images (like JPG files) to VDJ while both songs are playing.
geposted Thu 06 Mar 08 @ 9:23 pm
Yet another powerful use of the CLIPBANK...
geposted Fri 07 Mar 08 @ 12:17 am
In the 5.0.7 version, you can drop any clip on the video preview window of a mp3, and its gonna link the clip to this mp3.
Clipbank and visualizations are other solutions indeed
geposted Fri 07 Mar 08 @ 4:40 pm
Need to be a registered pro user, for most of the special effects, sorry.
geposted Fri 07 Mar 08 @ 5:15 pm
I'm just gettn back into the Dj joint. I wanna know what i need to purchase in order to mix videos and use turntables and CD mixers as well. My goal is to have 2 turntables with 2 cd players linked into the video mixer. So what do I need or is there a setup that involves less that I should use. I do need the turntables though because that feel is what I'm used to, but I want the CD player as well because my son is getting used to that feel. Please advise
geposted Fri 07 Mar 08 @ 6:24 pm
The Slideshow plugins will do this, and you can set the effect as the default for when a video is not being played :)
geposted Fri 07 Mar 08 @ 9:24 pm
You may want to post your question as a separate post so that people don't get confused with two different topics in the same thread.
geposted Fri 07 Mar 08 @ 10:18 pm
